Water pooling in BOSCH Dishwasher SMV45EX00E/24
Hello,
I'd like to ask your help regarding a fairly strange issue I have with a BOSCH SMV45EX00E/24 dishwasher: the washing cycle is working just fine, water comes in, cleans the dishes, used water is pumped out, and at the end of the cycle there is no water inside, but after a few hours, fresh / clean water keeps slowly filling in the bottom and the only way I can temporarily fix it is to turn the off the water. (One time it even overflown and caused the device to give error E15, I've eliminated water under the Styrofoam safety switch so that the error clears but that made me think there is something causing this).
After searching on the internet I've concluded that the water inlet valve needs to be replaced, which I just did, ordering an original piece, mounting it, but there is no change in the overall behavior, water is still slowly pouring in after a couple of hours, just like before.
Do you have any ideas which part should be checked next? I'm thinking of the water flow sensor.
Apart of that there is no other issue with the machine. (except it's not even three years old and behaving like this).
Any input is appreciated,
Thanks in advance,
Robert
Esta é uma boa pergunta?
