Ir para o conteúdo principal
The RIM BlackBerry Curve 8520 is a sleek entry-level smartphone that delivers some nice design enhancements and great performance
30 Perguntas Visualizar todos
doesnt charge, the part where the charger connects inside has broken
hello, i have had my blackberry for ages now, one day it was working fine and then i plugged it in to charge and it didnt respond. so i thought it was the charger so used my usb and it still didnt charge. the charger was really loose inside the phone so i took it out and the part where the charger goes inside the phone came out with the end of the charger. so i took it apart and then saw that the part where the charger bit inside the phone has snapped off the circuit board. i dont know how to fix it without buying a new phone or a new circuit board. help please.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
seems to be a common problem with this model and other blackberries.
A new charging port would have to be soldered on. This is pretty technical, so u might want to take it to a technician but the phones not ruined. probably $50-$60
Esta resposta foi útil?
Pontuação 0
I have the same problem with my android. You might wanna get it fixed or buy a new battery for your phone. It would probably work with me as well
Pontuação 0
Adicionar a sua resposta
laura será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 10,807
