Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone 11. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 11.
Replacing iPhone earpiece speaker; lost a Phillips screw. Will it work
I was replacing my iPhone 11 earpiece speaker and I lost a Phillips screw that holds the assembly inside the phone. Will the speaker still work or will it have issues if only 1 screw is missing from the assembly?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi
I think it will work fine as the speaker has separate connections and doesn’t use the screws for anything apart from holding itself to screen
I would replace it if given the chance though but it should work without it
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 1
It will most likely work, but if you are worried about it you could try to find a replacement screw. You can buy the sets of all the screws on eBay and a bunch of other places. Also make sure you replace the water proof seal when you finish the repair.
Pontuação 1
Adicionar a sua resposta
Juan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 283
