Noisy fan when cold
I have a noisy fan when first switched on, but it seems to go quiet when it's warmed up ,I've stripped it down and replaced the thermal paste and cleaned the heatsinks
Esta é uma boa pergunta?
Did you clean the bearing area underneath the fan?
Esta resposta foi útil?
Does this make a difference
Yes. If the bearings are filthy it will reduce performance and increase noise. @noggin343
It did have a small amount of play up and down, but didn't notice any type of noise spinning it by hand
@noggin343 this "noisy fan when first switched on quiet when it's warmed up" leads me to suggest that you replace the fan. Bad bearings etc will do this. PlayStation 3 Super Slim Fan Replacement
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 42
