Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
Power Button doesn't work.
The MacBook doesn't work when I press the power button, but when I unplug the battery and plug in the charger it turns on. So I think the power button is damaged. Can anyone tell me where I can get a power button and how to change it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The power button is part of the keyboard so you must replace the whole keyboard. A replacement keyboard for your MacBook Pro is easy to find on many places on the web just search for "A1278 US 2010 replacement keyboard", you should pay $30 for a new one. To replace the keyboard you must remove the logic board, the DVD drive , the backlight layer and + - 80 small philips screws. You should order the keyboard and the backlight layer cause the keyboard backlight is often damaged during removal. Check on youtube for a keyboard replacement tutorial.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Rodrigo Carvalho será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 58
