Ir para o conteúdo principal
Repair guides and information for portable, battery powered Bluetooth speakers
71 Perguntas Visualizar todos
JBL FLIP 5 can't couple 2 BT speakers - no audio
Hi,
I have two JBL FLIP 5 speakers that I wish to couple together in "party mode". Both speakers produce sound when used as primary speakers. But when I use one as primary (connected via BT to the audio source), and follow the procedure to couple the second one, the second loudspeaker emits a sound to confirm coupling but produces no sound. This happens whichever one of the two is primary. And I have previously used these same speakers in "partymode" without problem (even coupling 4 or 5 speakers together).
I can't find any troubleshooting help on this particular problem. Can anyone help ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Download the jbl app and use that to pair them.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Glad to help. You can only try it. See if there is a jbl app for pc, I’ve never looked to be honest.
por
Thankyou. ! Yes that worked !
It just means tht I have to run them through a phone, when a computer would be more useful.
I'm wondering if I should try uprgrading their firmware, to be sure they're of exactly the same generation ?
Pontuação 0
Adicionar a sua resposta
Adam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 36
