Ir para o conteúdo principal
Repair guides and support for top and front loading Whirlpool brand washers.
405 Perguntas Visualizar todos
Whirlpool Duet Washer Error codes
When I power on my Whirlpool Duet front load washer I receive error codes E01 and F01. Do I need to replace my central control unit or should I start with just replacing the memory?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
gasrrmm s usually you already know that this error associated with the central control unit. Sometimes it is possible that this is a bad EEPROM which is for storing re-recordable data for your washer. If you know which EEPROM that is and if you have it, then I say go for it. If not, then it could cost you more since you may still need a new CCU. It's a bit difficult to answer precisely since we do not know your skill level, if you have the tools and if you have the part. Nothing wrong with trying to fix the board.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you for your response
por
Adicionar a sua resposta
gasrrmm será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 36
Duração total: 622
