Ir para o conteúdo principal
Repair information for tools used to clean drains.
9 Perguntas Visualizar todos
I need to splice two pieces of 1/2 inch auger cable together
i need to order a splicer for a 1/2 inch auger cable what is the part number
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
There are two types of repairs;
https://drainbrain.com/en/products/cable...
Insert screwed into hollow cables; https://www.youtube.com/watch?v=ts1y8rWa...
por
Adicionar um comentário
1 resposta
If you search "how to splice two pieces of half inch auger cable together" there will be a YouTube video for Roto-Rooter that shows you exactly how to do it and when to and when not to. Here is the link that I copied for the video if you're not comfortable following links do the Google search and the YouTube video should pop up good luck.
https://youtu.be/ts1y8rWaTY8
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
chad kee será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 93
