Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
Why is my new Crucial MX500 SSD not partition supported?
Just purchased this sad from you and installed but when booting up to disk utility the new SSD is showing Partition Map as “not supported”. When I tried to erase and rename it’s giving me an error of “erase process failed”. How can I get the SSD loaded with an OS and working?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
First, the blog space is answered by volunteers. You'll need to speak directly to the iFixit store to exchange out the SSD to a different one.
You are facing a known issue many people face as they forget the SATA interface has been upgraded a few times from the original SATA I (1.5Gb's) to SATA II (3.0 Gb's) and last update to the standard SATA III (6.0 Gb's).
The standards group had a bit of a dilemma which was the more important direction of compatibility! Taking older standards based drives sticking them into newer systems or the reverse having compatibility of installing newer standards based drives into older systems. At the time it was more common a practice to upgrade the system reusing the older drives as they where more expensive! Which is how the Standard was set. Older Drives supported in newer systems, not the other way.
Even still the drive makers realized they needed to offer a way to allow people to upgrade their drives in older systems. Many offered a jumper to alter the drives data rate to one that was compatible with the older systems. Later on it was done automatically set based on the technology used in Ethernet to auto sense the data rate of the switch ports and even migrated to the Ethernet adapters.
Here we use the term Fixed Speed and Auto Sense to describe a SATA drive port speed. For quite a few years we had both fixed and auto sense HDD's but as the market for upgrading the older systems dried up and the pressure to lower costs many drive makers pulled the Auto Sense technology reverting to Fix Speed at the higher SATA III (6.0 Gb's) rate as there was more systems in use using SATA III now. Likewise the SSD makers where also looking at ways to lower the costs and many also followed!
So with that brief history on SATA lets get into you problem!
Sadly, the Crucial MX500 SSD is a fixed speed SATA III (6.0 Gb/s) drive and you system 13" MacBook Pro 2.4 or 2.66 GHz Core 2 Duo (Mid-2010) is only a SATA II (3.0 Gb/s) so the bottom line here is the drive is too fast for your system.
You need a drive which is able to run with the systems SATA II (3.0 Gb/s) ports I/O There are still a few SSD's that offer Auto Sense which will work Samsung 870 EVO or Samsung 870 QVO
If you review these spec sheets you'll see clearly written
SATA 6 Gbps Interface, compatible with SATA 3 Gbps & 1.5 Gbps interfaces
To add to this here's the Crucial MX500 spec sheet it clearly states SATA 6 Gb/s interface only!
So unless the spec sheet offers a clear listing of multiple I/O speeds Auto Sense its strictly a Fixed speed drive and will only work within a system which offers the Same I/O speed.
Esta resposta foi útil?
Pontuação 4
7 comentários:
Hi Dan, thanks so much for the information it has been extremely helpful. One more quick question. It seems the 870EVO comes in both a 250 or a 500gb option. Do you recommend one for my computer or is either ok?
por
@angielu - Storage size is mostly a personal thing! What I need and what you could need is likely very different! My 2012 15" MacBook Pro has a 2 TB drive as I hold a lot of documents on it. My MacPro has two 8TB RAID drive sets for my passion in ultra-large image photography used in Theater backdrops and other presentation's.
So is 250 enough space for your needs? If you think it might not get the 500.
por
Thanks Dan! Appreciate all the help!!
por
Hi Dan, sorry to bug you yet again but I’m back to the same issue after installing the correct disk. I am not able to erase/re-name it in disk utility. I’m getting a “erase process has failed” error with the details “unmounting disk, creating the partition map, unable to write the last block of the device, operation failed…”. Please Help?!
por
@angielu - Are you facing the shoe cobblers dilemma? That is when you to to the shoe maker to get your shoe fixed, he can't fix it while you are wearing them can he, he asked you to remove your shoe so he can work on it.
Here we need to boot up under a different disk as you can't alter the disk while you are also leveraging it as the boot drive.
Do you have a bootable external drive?
por
Exibir mais 2 comentários
I do have an external hard drive that I used to back up this computer. Will that work and if so can you tell me the steps that will get this job completed?
Pontuação 0
Adicionar a sua resposta
Angie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 599
