Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
604 Perguntas Visualizar todos
My my mac wont turn on.
I ended up picking it up with the owner saying awhile ago they were playing sims when it just shut off.
i opened it up to take a look around and i noticed when i plug the charger in you can smell a smoke smell from where the port is.
could the i/o board be the issue or could it be something else to why it wont boot up.
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta Mais Útil
If you smell smoke you will want to immediately turn the device off and disconnect the battery. You're going to want to make sure that there are no burn marks on either of the boards or any components. I would also inspect inside the ports to make sure that there are no burn marks there either. I would also upload your findings here if you find anything.
- Adicionar imagens a uma pergunta já existente.
- MacBook Air 13" Early 2015 Logic Board Replacement
- MacBook Air 13" Early 2015 I/O Board Replacement
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de MacBook Air 13" Early 2015 Logic Board
Guia
Moderada
1 - 2 hours
Imagem de MacBook Air 13" Early 2015 I/O Board
Guia
Moderada
35 minutes
Esta resposta foi útil?
Pontuação 1
1 dos comentários:
Maybe some part of the computer must of been fried in the process possible from overuse?
por
To me its sounds like its the logic board,
Part: MacBook Air 13" (Early 2015) 2.2 GHz Logic Board or MacBook Air 13" (Early 2015) 2.2 GHz Logic Board
Guide: MacBook Air 13" Early 2015 Logic Board Replacement
Imagem de MacBook Air 13" (Early 2015) 2.2 GHz Logic Board
Produto
$349.99
Pontuação 1
Adicionar a sua resposta
Laminat3 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 64
