Ir para o conteúdo principal
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Keyboard and keypad doesn't work
Keyboard and keypad doesn't work on my MacBook Air except the power on an off
Could it be the ribbon?
This is the ribbon on the end that looks like corrosion
The ribbon
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Yes, it does look like corrosion damage. While the cable should be replaced, I fear your trackpad likely needs replacement too!
Here's the guide MacBook Air 11" Early 2015 Trackpad Replacement
Imagem de Replace the cable that connects the trackpad to the logic board compatible with the Mid 2013 to Early 2015 11" A1465 model MacBook Air laptop. Part #923-0432, 593-1603.
Produto
MacBook Air 11" (Mid 2013-Early 2015) Trackpad Cable
$14.99
Imagem de Replace a trackpad compatible with the Mid 2013 to Early 2015 MacBook Air 11" model A1465 laptop. Part #923-0429.
Produto
$57.99
Esta resposta foi útil?
Pontuação 1
1 comentário:
I agree, :-)
por
Adicionar a sua resposta
Deron Ramjattan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 105
