Metal ring plate?
I had a little metal ring plate with a hole in the middle fell out the rear panel ? Where does it fit ?
Esta é uma boa pergunta?
Might be the small piece that helps hold down the camera at the top screw. This one is really not necessary to be replaced. Another is the ring tab on the antenna flex that is screwed down to the bezel at the dock. Take a look at those places.
Esta resposta foi útil?
not sure what part you are talking about. go through the take apart guides and find the piece and what step number then I can help you.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 358
