Why my device stuck on Samsung logo and charging logo doesn't started
When I was charged my Device it stuck on charging logo when I press volume down and power on key then it stuck on charging logo but it is not starting
Esta é uma boa pergunta?
Volume down and power is usually download mode for Odin. Try pressing and holding volume up and power for 20 to 30 seconds. If it works you should get a screen with different options. Scroll to clear cache then press power to select it. Click yes again if asked are you sure then select restart or start phone. Try that, hope it helps.
Esta resposta foi útil?
Commonly it's a mother board beoblem
When the contact between CPU and ram become loss contact , you moble become stuck on Samsung logo
You need to remove both CPU and Ram And reball the both IC and refix to mother board
It's the permanent solution....
It's have 💯 success ratio..
As Usual All Samsung A Series ,M Series and F Series have this Common Problem.
If you want to do Temporary Solution,just leave the phone in Sunlight for 1Hour in Open Sunlight in Power Off Condition,Than check,If Solved it's a CPu and Ram Communication Problem
Últimas 24 horas: 4
Últimos 7 dias: 39
Últimos 30 dias: 163
Duração total: 6,211
