Ir para o conteúdo principal
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
247 Perguntas Visualizar todos
iPhone SE 2020, restarting every 180s because of tg0b, board defect?
Hello Guys, i need help. I have an iPhone SE 2020, replaced screen (by me) which is now kernel panicking and restarting every 180s (has nothing to do with the kernel panicking, screen replacement was done now a year ago). It has no obvious pry damage, the mosfet by the battery connector is still in place and not moveable. With both the OEM Battery and a new 3rd party one the kernel panic keeps happening as well as the 0% battery charge thing. In the logs "missing tg0b" is stated. When starting without the dock and front camera flex attached the logs state "missing tg0b and mic1", so i suppose its a board issue? Any tips?
Update (07/26/2022)
The battery connector
Esta é uma boa pergunta?
Pontuação 1
1 comentário
One of the data pins looks to be pushed into the plastic but I cannot be certain. The measurements you took are okay.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
This does sound like a battery data problem. The first thing to check would be the battery connector as they are known to be problematic on this model. Check the pins have not been pushed into the plastic, if they have you will need to pry them out. The next step would be measuring the pins with a multimeter in diode mode. Also there are two fetts near the battery connector not just one.
Esta resposta foi útil?
Pontuação 1
1 comentário:
i measured the pins and got the following readings: GND for GND and 418 for the 2 big pads on the other side as well as 689 for the data pins. Ill post in another comment a picture of the connector
por
Hi Benjemiah,
The error code refers to Temperature monitoring chip on the motherboard stopped working due to no feedback from the temperature sensor it has gone to fail safe mode (restart for every 3 mins)
Pontuação 0
1 comentário:
So it is not a Battery SWI Problem? How can it be fixed?
por
See this youtube link: https://www.youtube.com/watch?v=GSH2Y-Sp...
This will show in detail the circuit board issue
This is reference to the Panic restart every three minutes with reference to Mic1 not being found
Pontuação 0
Adicionar a sua resposta
benjemiah será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 32
Duração total: 424
