Ir para o conteúdo principal
The Ryobi RS290G is a powerful Orbit Sander that boasts 12,500 rotations per minute. With an Ergonomic Grip to stabilize, and a dust bag to collect debris it is the perfect all-round sander.
Why is my Ryobi making a weird noise?
My Ryobi sander started making a strange noise and is not sanding proper. I made sure there were no loose screws, cleaned it and then let it sit for a few hours to cool down as I had been sanding on and off for several hours. Unfortunately none of these seemed to help. What could be causing this and is it fixable ?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
What sander is it? Belt, orbital, detail sander?
por
It is a Ryobi corded orbital sander
por
Adicionar um comentário
1 resposta
Solução escolhida
Possibly a bearing going, either to or bottom. I’d split it in two and remove the motor and check them. Could be wear on the base where the bearing sits.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
bhowse@live.ca será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 686
