Ir para o conteúdo principal
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
151 Perguntas Visualizar todos
Can I change the back cover on the iPad 3G?
Hello, I have a 64GB iPad 2 "Wi-Fi + 3G", and I'm wondering if I can change the back metal (aluminum?) cover on it.
As the kids have dropped it many times on the floor that I'm fortunate that the screen hasn't cracked.
The corners of the iPad are heavily damaged though, so are the sides.
Is there a way that I can simply buy another cover and replace it? Or will I have to dig through all the components of the iPad.
Esta pergunta é pertinente?
Pontuação -1
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
replacing the backcover isn't easy - you have to remove everything
maybe you should think about something like that: Marware ConvertibleShell for iPad
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
MSM será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,190
