Ir para o conteúdo principal
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
231 Perguntas Visualizar todos
Identifieng motherboard component 220 | 6NF3E
I was fiddling with the MacBook's mainboard, and accidentally damage one of the components. The one that has a marking "220 | 6NF3E | d"
I assume it's a diode of some sort, but that is the limit of my knowledge. Now I wonder what the proper replacement would be.
Thank you.
Esta é uma boa pergunta?
Pontuação 0
3 comentários
The large black three rectangular devices are tantalum capacitors you are referencing. I don't see any damage so I'm not sure thats your issue.
How about telling us a bit more here what happened, did you see spark or hear a pop sound or smell any smoke?
When you tried using the system what did it do and not do. The more you tell us the easier it is to help you.
por
The damaged one is not in the photo. it's simple mechanical damage. I was investigating the source of the short in the motherboard and accidentally ripped off the pad from the component while desoldering.
And yeah, the board still has a short somewhere. I just ran out of ideas on how to pinpoint it.
All small caps near the processor also shorted, so a assume it has something to do with VRM.
por
Okay after some tantalum rabbit hole exploration
220 - capacity (220μF)
d - 7343 case.
the rest - batch number of sorts
Those are probably custom components but reclaimed parts are somewhat available on Chinese marketplaces.
por
Adicionar um comentário
1 resposta
Solução escolhida
OK, so that explains the image is not the area of your damaged system. It would be helpful if you did offer the area so we can ID the area affected, which can let lead us to what's shorting out.
First i would snag the schematics and boardview drawings for your system do a google search for 820-00239 which is the logic boards number. Then you should be able to trace back the logic to isolate what has failed/shorted.
Esta resposta foi útil?
Pontuação 1
2 comentários:
That info helped a lot. I googled the schematics, and that's C1191, 220uF 2V
I'll try to isolate the problem by myself (learning new stuff is always good), but probably will ask a separate question later.
por
And yeah, reading schematics is much more insightful, than just randomly desolder fragile components from the board. Who knew?
por
Adicionar a sua resposta
Lev será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 48
