What size screwdriver is needed I've tried a t2 which is too big
Can anyone tell me what size screwdriver I need to fix my versa 2 I've been told a t2 which I've tried it's too big x
Esta é uma boa pergunta?
Hi
If a T2 is too big try a T1 they are quite similar but a T1 is smaller
Also if it has a pin in the middle it is a security torx and you will need a specific security torx to take it out
Hopefully this helps
Esta resposta foi útil?
Thank you so much x it actually turned out to be a t2 it's just the quality of the driver I'd borrowed wasn't the best so as advised tried t1 and that did fit then snapped so bought new torx set and t2 fit straight away. Thank you for responding.
@Emma Rowell
Your most welcome:-)
If you need any more help just ask:-)
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 32
Duração total: 194
