Battery 100% charge - same problem before and after battry switch
Before switch of battery it only worked 4-5 min, we have change battery and loading it works well, but when we take out the electricity cord, it go off?
Before battery switch - it random go off ?
Macbook Pro 13 inch - early 2015
Haven´t heard about this before -
Esta é uma boa pergunta?
What is the color of the MagSafe cords LED Amber or Green?
If you can install this app CoconutBattery take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
por Dan
Picture up, and the light is green, we also can see that it worked some seconds alone on battery, that problem started before battery switch
por Sven Olov Dahlgren
it random goes off whit cord, and goes 2-10 sek on battery, battery is full loaded. it shows amber color in a few seconds and then green
OK i have done the SMC 10 times or more, but it dosent relese the old battery data??
Installed the new battery who showed about 40-60% and then it loaded upp to 100%
But when we look in the mac after downgrade the mac to el capitain we can se this in the system -power
Coocanut battery do not work on this OS
Translated from swedish:
Battery information:
Model information:
Serial number: C01514309YEF90MA4 <<<< The old battery that we have replaced
Manufacturer: SMP
Device name: bq20z451
Pack Lot Code: 3230
PCB Lot Code: 3230
Firmware Version: 2d31
Hardware audit: 322d
Cell revision: 3036
Charging information:
Remaining charge (mAh): 6492 <<<< not loaded
Fully charged: No.
Loading: No.
Full charge (mAh): 6600
Status information:
Number of cycles: 1
Condition: Normal
Battery installed: Yes
Ampertal (mA): 0
Voltage (mV): 12394
@swedboy - Over time CoconutBattery has kept up with the newer versions of macOS, as such some OS API's dependent on in the older versions were discontinued by Apple replaced by newer ones which the newest version of CoconutBattery now uses.
You'll need to contact chris (at) coconut-flavour.com to get the older version if you are going the stick with El Capitan. Not sure why you rolled back as the OS is not the issue here.
If you've followed my instructions to the letter, then I think it's time to try a different battery. Clearing SMC only sets a flag state, so its possible the battery data line is not working properly.
por Dan
Exibir mais 1 comentário
