Element TV ELEFS552 no picture no sound
I have had all the controls board replaced with new ones. When I turn the tv on nothing happens. They replaced the led boards today and the only image I get is a flicker when turning the tv off. There is no sound no picture and I am needing help since my tv guy is not getting it done.
Esta é uma boa pergunta?
Pontuação
0
@llama_dr If all the boards are replaced with brand new parts, and still nothing, it could be the screen itself?
If you turn the TV on as normal, and then turn off all the light in the room (make it as dark as possible), and then shine a flashlight onto the screen from different angles (from up close), do you see a very dim picture on there? If so, then it's the backlight that has taken a dir nap :/
por Geir Ove Andersen
Thank you for the input I have done this task and can see I little image
I have replaced all the boards, leds and power supply.
Any ideas where to do next?
por Chuck Balogh
@llama_dr If you have replaced all boards, including LED backlight driver AND the actual LED backlight, then it sounds like the "new" parts that were put in is faulty. If you can see a faint image, when doing this test, there is definite problems with the backlight.
@ geirandersen is there away to know the screen is bad? For sure. Thank you for your input
por Chuck Balogh
@llama_dr Well, if you can make out an image (although very dim), and if you inspect it as much as you can without seeing clear damage (to the picture), I'd say the screen itself is OK; Just the backlight problem.
Exibir mais 1 comentário
