Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
859 Perguntas Ver todas
My pc doesn't recognized the iPod, nor itunes.
Otherwise it works fine. It charges, I can play the music in it... but I cannot add more music because when I plug in, the pc says that an usb device is not working properly.
I have try with different pcs and different cables with the same result.
I have try to reset the iPod too.
Which can be the problem?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
5 Soluções
Solução escolhida
get a good iPod to computer cable. the cheap ones fail. i'm sorry this is so simple. but it will work 90% of the time
Esta resposta foi útil?
Pontuação 2
Comentários:
perhaps not 90% of the time, but it is a good idea.
por
This sounds like an unusual mishap, I would of recommended deleting and re-installing itunes or trying different cables like Mayer recommended, but if you say you have tried different PC's and cables, then it sounds like an issue with your iPod and you say you have tried to reset it already so I'm out of recommendations. I'm sure one of the iPod experts in here will recommend other trouble-shooting methods.
Pontuação 1
Thanks
Yes, I have tried with 3 different cables (all apple originals) and nothing. And I have 2 iPods, and the cables work fine with the other.
I fear it could be the logic board :(
Pontuação 0
anyone else witha answer my daughters does the same other iPods are seen by itunes I even reinstalled itunes on lap top plug in iPod it just plays on screen of iPod like no wire is pluged to it I also belive it is the logic board but at 70 bucks I will buy another iPod but if i can try somthing else let us know this has been going on awhile so would be nice to fix for her thanks
Pontuação 0
Comentários:
Ok this site rocks learned so much first iPod repair changed logic board out and iPod is up and running lost everything but have running iPod still say that 70 dollars for logic board is not worth the repair but I traded with a freind for other parts and we both have fixed iPods
por
I think I've got the same problem with my Classic 5g. )-:
Pontuação 0
Adicionar a sua resposta
Azucena será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 731
