Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
548 Perguntas Visualizar todos
should I clean my fans manually or replace them?
my fans are dusty and i am wondering if i should clean them myself or just replace them entirely?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
Cleaning is quite easy! Get a small soft pain brush and a can of can'ed air so you can blow out the dust & debris.
I would follow these two guides as its better if you remove them:
Carefully scrub the blades as well as the heatsink fin areas. I blow the air outward across the fins and a few short blasts on the fans. You don't want to spin them up, I often carefully wedge a toothpick to hold the blades from moving. Don't for get the give the logic board a quick wipe as well with the brush and then blow off what you've loosened up.
Imagem de MacBook Pro 15" Retina Display Mid 2012 Right Fan
Guia
MacBook Pro 15" Retina Display Mid 2012 Right Fan Replacement
Nível de dificuldade:
Moderada
45 minutes
Imagem de MacBook Pro 15" Retina Display Mid 2012 Left Fan
Guia
MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement
Moderada
20 minutes - 1 hour
Esta resposta foi útil?
Pontuação 2
1 dos comentários:
Thanks for the help
por
Adicionar a sua resposta
Jake Pfaff será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 62
