Ir para o conteúdo principal
Repair, disassembly, and troubleshooting information for the Steam Deck with LCD display, a handheld gaming console made by Valve, released on February 25, 2022. Identified by model number 1010.
251 Perguntas Visualizar todos
What screw is used in the silver shield casing?
I feel as though i've ruined one of the screw heads holding the silver shield, this was while attempting an SSD upgrade. what is the replacement screw?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
A standard M.2. Screw is 2.0 x 3mm (CM2x3-3.3). Ace hardware has them. But as @jayeff says the video doesn't specify check length and thread and verify it's the same.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
See Step.5 in the ifixit Substituição do SSD do Steam Deck guide to see the length of the Philips #0 or #1 screws used to hold the shield. The guide doesn't specify which size Philips driver is used, only the length of the screw is shown.
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Paul Finn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 739
