My Nintendo switch pro controller won't charge or Turn on
After leaving my Pro Controller charging for more than an Hour it will not turn on or charge. Holding down the Sync button also does not work
Esta é uma boa pergunta?
Needs a new battery it seems like. Very easy to replace, all you need is a pretty tiny Phillips head screwdriver. Screw off the screws on the bottom of the black grips, then those 4 screws on the inside. You should be able to pop the backplate off and have access to the battery.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 207
