Ir para o conteúdo principal
The TI-84 Plus CSE was a graphing calculator by Texas Instruments released in 2014. It was the first TI-84 to be equipped with a color screen.
4 Perguntas Visualizar todos
Calculator won't charge - I think it's my port
My TI 84 plus c was working great for a long time, but recently I couldn't get it to turn on and the LED bar on the side would not light up when i plugged it in. I bought a new battery and charger from Amazon and installed it, but it still won't light up on the side. The battery had 25% charge in it so I could use it for a little bit - I need it for one more course.
I guess I'm wondering if there is any way I could tell that my port is broken or if there is anything I can play around with to get it to charge. My charger sits firmly-ish in the slot, it wiggles form side to side a bit if I play with it. Even when I move it around, the light doesn't even flash to show that I've got a charge even for a second. Any advice would be great!
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Look into the port and see if anything looks wrong. Maybe you will have to replace the port, which would most likely require soldering to do.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Marie M será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 41
