Why wont my phone recives any signal?
After a hard fall my iphone on sparadicly recives any sort of signal, 3g or network. What would be the most likly cause of this?
Esta é uma boa pergunta?
Two main reasons this has happened
- Loost antenna connection due to impact force
- Damaged logic board
If the antenna has become loose, all you will need to do is remove the back cover and re-seat. If the logic board has been damaged then you will need to take your phone to apple and request for a replacement.
Esta resposta foi útil?
usually a loose antenna
you can change your sim card and try it .if that your cellphone doesnt work ,maybe it was broken.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 779
2 comentários
Seeber, can you tell us which iPhone you have?
por Phillip Takahashi
i have the iPhone 4 first gen.
por seeber
