Ir para o conteúdo principal
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Perguntas Visualizar todos
Clicking noise in a 27" iMac 2012
I have a clicking noise coming from my 27" iMac 2012 A1419 system
  • I replaced Power Supply board
  • Unplugged Cooler Fan
But noise is still same.
When i start CPU stress test, CPU temperatures go around 90~105 degree, i can hear this noise.
It sounds from Logic Board, i guess.
Update (05/07/2022)
@danj
For testing, i unplugged the fan, but noise is same.
I think this noise is not related with Power Supply or Fan or HDD.
I recorded this noise.
https://drive.google.com/file/d/1GVuTu8l...
After this noise starting , CPU temperature is down to 80 degree.
Is that a throttling noise?
@areeve
In my imac, there is no HDD.
There is only SSD.
Update (05/20/2022)
Finally, i solve this problem.
The problem was heatsink. i replaced the heatsink, and annoying noise and high temperature were disappeared.
I installed the old heatsink in another imac, and there were crackling noise and high temperature.
Thanks.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
The sound appears to be more of a slapping sound than a discharge sound. Clearly someone is flapping around. I would look for a scrap of paper or loose tape within the fan. While you stated you disconnected the fan I'm not convinced you had, as I still hear it!
por
Well you had me stumped! 95~105 ℉ is within the normal range. I wouldn't have expected the coolant boiling would have made such a strange sound. Clearly you have a leak in the heat transfer pipe did you see any holes?
por
Adicionar um comentário
3 respostas
Solução escolhida
@danj & @areeve
Finally, I solved the problem!
The problem was the heatsink. I replaced the heatsink, and annoying noise and high temperature were disappeared.
I installed the old heatsink in another iMac and there were crackling noise and high temperature.
Thanks.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
I would check the hard drive. A lot of times they start the “click of death” before they fail. Substituição do disco rígido do iMac Intel 27" EMC 2546
Pontuação 2
Clicking sounds as you describe is more likely the fan bearing and/or blade hitting the fan's cowling if nothing else is wrong.iMac Intel 27" (Late 2012-Late 2015) Fan ands here's the guide iMac Intel 27" EMC 2546 Fan Replacement
Imagem de iMac Intel 27" (Late 2012-Late 2015) Fan
Produto
$62.99
Pontuação 0
Adicionar a sua resposta
cappro será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 420
