plugging in firewire shuts down the machine
I have completely lost all fire wire on both my Mac Book core duo running OS 10.4.11 and my Mac Mini. When I plug a cable into the Macbook, the machine shuts down. the Mac Mini just doesn't see any fire wire connected equipment. I cannot use my Panasonic or Sony digital cams or connect my OWC Mercury external drive (it will connect thru USB)
Esta é uma boa pergunta?
2 comentários
Just Located the discs. Am unable to find the hardware test
por Tom
Put in the install disk 1 (the grey one) and then unplug everything from the computer except for the power. Then restart the computer while holding the "D" key. After you have selected your language then you should choose "preform extended testing" and see you results. Tell us what it says because this could root out a problem.
por Owen Cunneely
