Ir para o conteúdo principal
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Perguntas Visualizar todos
MacPro 1,1, cpu b+cpu a lights come on when plugged in, wont boot,dead
Neighbor threw away a his old macpro 1,1, hasnt been turned on since about 2016 (6 years), i got it, plugged it in turned right on, used it for about 30 mins, turned it off, went back to it about 20 mins later, nothing, just 2 red lights that say cpu a+ b overheat, its been 2 days, still doing the same thing. Psu i tested and its good, took out the gpu, swapped ram boards with another macpro, still doing the same thing. Anyone know?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Did you replace the PRAM battery and check the CPU's (apply fresh TIM and make sure the coolant hadn't leaked out of the heat sink)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Evan The Person será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 65
