Ir para o conteúdo principal
2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
Replaced battery, not charging and shuts off when disconnected
I just replaced the battery in my early 2013 13" Mac Book Pro Retina. Followed all of the iFixit directions. Battery percentage shows the lightning bolt like it's charging (says 0%). When I initially plugged it in the orange light was on, but now it's green (still shows 0%). When I unplug from the power source it turns off immediately. I reset the SMC, but nothing changed. Did I do something wrong during the install?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Make sure the battery in plugged in properly, Those connectors can be a bit tough. if that doesn't work test your original battery in the laptop, if that works you most likely have a faulty replacement battery.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lesia Wasio será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 70
