Ir para o conteúdo principal
Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
101 Perguntas Visualizar todos
Don’t turn on
does not turn on. I tried all combinations with the power button but the computer does not respond. when I get off the charger, then the charger heats up as usual, but the computer itself does not react
Esta é uma boa pergunta?
Pontuação 1
6 comentários:
Have you spilled any liquid, dropped it, or any other damaging things lately?
por
no, absolutely nothing like that...
por
Have you tried replacing the battery?
por
I doubt it is the battery as it don’t power on with the brick and it is only 2 years old.@guardian10
por
haven't tried it yet@guardian10
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Try the SMC reset on the mac,
https://discussions.apple.com/docs/DOC36....
If you are comfortable with taking the back off unplug the battery and plug it back in. and try start it again with the charger plugged in.
if this doesn't work you can try plug it into the charger and start it without the battery plugged in.
Esta resposta foi útil?
Pontuação -1
1 comentário:
unfortunately does not help
por
Adicionar a sua resposta
Irakli Kvirkvelia será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 251
