Ir para o conteúdo principal
How to fix stuck bootlooping
how to fix iPhone 6 s plus boot looping I have this iPhone 6s plus that has a good battery and is stuck boot looping I was using it and it just froze and then I turned it off and then once I did this it just rebooted and now has been like this for a couple of hrs how do I fix this problem also the phone does this when unpluged
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Put the phone into recovery mode and do an update with iTunes or 3uTools. Let us know if you receive an error.
Esta resposta foi útil?
Pontuação 1
9 comentários:
i tried to put the phone i recovery mode by pressing and holding the home button and off button but it just shut off and then when i let go it still just went back on am i doing it right?
por
@keith_themuscovyduck Keep holding the home button and power button, the phone will eventually shut down and restart keep holding the buttons until recovery mode. If it will not go into recovery mode you could try DFU mode but you might have to do a restore instead of update.
por
ok thanks i got it in recovery mode
por
@imicrosoldering
i updated and its still bootlooping
por
@keith_themuscovyduck If it updated without any errors you will need to rule out a parts issue. Replace the battery first.
por
Exibir mais 4 comentários
Adicionar a sua resposta
keith_themuscovyduck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 114
