Stripped srew on back of MacBookpfro
I need to replace the fan in my Macbookpro. The problem is that there is a stripped screw on the back of the Macbook. How do I remedy the problem without taking it to the genius bar?
Esta é uma boa pergunta?
You need a jeweller's screw extractor. Look for for a jeweller's tool supply firm. You will need to look around a bit for it as they are much smaller than the ones you normally find at machine shops.
You will want the type that requires drilling a pilot hole first. They are conical in shape with steep spiral cutting edges that cut into the screw in the pilot hole turning counter clock-wise to unscrew it. Read up on the technique as much as you can before actually doing anything, to avoid a disaster.
The most common cause of stripped screw heads is insufficient pressure on the screw driver that then allows it to slip on the screw head.
Good luck.
Esta resposta foi útil?
Thank you for the advice. I will search for the part.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 42
