Ir para o conteúdo principal
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
239 Perguntas Visualizar todos
How to disconnect antennas?
Hi.
Can anyone tell me:
1)
Where are the following antennas on the Iphone SE (2020) (2nd gen):
a) 2G, 3G and 4G?
b) GPS
c) Bluetooth
d) NFC
e) Wifi
2)
How to disconnect all these antennas (and still be able to use USB On-The-Go features (like USB to ethernet)).
3)
Same questions for
a) Samsung Galaxy (like A41)
b) Sony Xperia (like 10 II and 5)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
why would you want to disconnect all of these antennas but still use ethernet?
here's the guide on how to disconnect the antenna iPhone SE 2020 Logic Board Replacement
here's the guide on how to disconnect the wifi diversity antenna diPhone SE 2020 Wi-Fi Diversity Antenna Replacement
bear in mind these may not entirely disable all of the functions. I also believe some of the antenna functions run through the charge port and if you want to keep usb ethernet, you're going to have to leave that connected.
Imagem de iPhone SE 2020 Logic Board
Guia
Nível de dificuldade:
Moderada
45 minutes - 2 hours
Imagem de iPhone SE 2020 Wi-Fi Diversity Antenna
Guia
Moderada
30 minutes - 1 hour
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
azaris será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 149
