Ir para o conteúdo principal
Released in 2007, identified by model number WD-57734.
16 Perguntas Visualizar todos
Green blinking light on the timer status & tv wont come on
What does the green blinking light under the timer status button mean
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
Hi,
Here’s what a green blinking timer light can indicate. (scroll down the page to Timer Indicator)
If none of these events have occurred, then try a system reset and check if that fixes the problem.
If still no good try a power reset by turning off the TV and disconnecting it from the wall outlet. Then press and hold the TV’s Power On button (the one on the TV, not the remote) for a full 30 seconds and then release it. reconnect the power to the TV and turn it on. Hopefully the green blinking light will cease after ~60 seconds and the TV will operate normally.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Neal Chatman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Duração total: 137
