Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
MacBook optical drive in iBook
Can I replace iBook G4's optical drive with one from MacBook (A1181)?
Esta pergunta é pertinente?
Pontuação 0
Comentários:
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it form the unanswered list.
por
Adicionar um comentário
3 respostas
Solução escolhida
MacBook drives use the same PATA interface until the Early/Mid 2009 models.
Regardless, iBooks use a full-sized drive, and the MacBooks use slimline drives, so they are not compatible. Sorry!
Esta resposta foi útil?
Pontuação 1
Pergunta Mais Útil
They're definitely not inter- changeable. The iBook uses Pata connector and the A1181 uses a sata interface.
Pontuação 3
Comentários:
Are you thinking of hard drives? The A1181 uses the same interface until Early 2009 models.
por
You're right Ben, good eye!!! I was thinking hard drives. Thanks for the pull_up!!
por
As you can see here, I don't believe that the drives are interchangeable.
Pontuação 1
Adicionar a sua resposta
teeeveee será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,096
