Why is my MacBook running slow after a successful fan replacement?
I replaced my MacBook’s fan after running Diagnostics and receiving a PPF003/PPF004 error message.
I followed the step-by-step iFixit guide and a few videos and installed it successfully.
After the installation, I ran Diagnostics again and received a ADP000 reference code with the message “No issues found”, however, the computer still runs pretty slow. Not as slow as before the fan replacement, but still at a speed that is far from ideal.
Other updates I’ve done over the past two years include upgrading the original HDD to a SSD and replacing the SATA cable. What else could I do to increase performance? Thanks in advance!
Esta é uma boa pergunta?
2 comentários
What is the SSD you put in make & model? How much RAM do you have installed? How full is your drive? Cap Vs Used
Did you try backing up your system and then reformatting the drive and installing a fresh copy of the OS?
por Dan
Hi, Dan! I put in a Samsung 860 EVO 1 TB. The drive has 882.24 GB available of 999.86 GB. I have 8 GB of RAM installed, 4 GB in each slot.
I have not tried reformatting the drive and installing a fresh copy of the OS. The computer currently has Mojave (Version 10.14.4). The computer loads very slowly at the moment and buffers often, so I’m not sure what’s the best approach.
This all happened suddenly. I hadn’t encountered any issues with performance like this prior to about a week ago.
por Daniella
