Circular blotch on new screen?
An hour after replacing my battery and screen with the iFixit LCD screen and battery, a circular spot started appearing. Has anyone seen this before?
Edit: added images
Esta é uma boa pergunta?
Edit: added images
Hi
Hope you are well
Have you tried removing the display
As from the picture it looks like a pressure mark
Esta resposta foi útil?
It seems like a pressure mark (as you both advised). I decided to accept the mark, to avoid breaking the screen seal. But I wanted to thank you both again for your help @Duane and @hellomacos. It’s a wonderful community with you here 🙂
Your welcome any more questions
We are here to answer them
Sounds like a display issue. Especially if you've fitted the XS with an LCD rather than OLED.
Also check if anything is stuck behind the display.
A picture would help here.
Sorry about that Duane – I have uploaded images.
I should have taken a photo before removing the display, but I didn't notice anything protruding behind the display. Actually, I removed the FaceID and speaker components – so there are fewer wires in that area.
Luckily, this blotch has not expanded and is acceptable at this size. If it does expand, I will remove the screen again and take a photo.
Thank you!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 47
2 comentários
Hi
Can you post a picture of the screen so I can better diagnose the issue
por HelloMacOS
@hellomacos Apologies, I have uploaded images. Thanks!
por Michael McGreal
