Ir para o conteúdo principal
A linha de laptops MacBook Pro da Apple foi concebida para usuários avançados e profissionais. Atualmente, a linha MacBook Pro inclui as variantes de 13, 14, 15, 16 e 17 polegadas, com revisões maiores definidas pelos designs Pré-monobloco (original), monobloco, tela Retina, Touch Bar e SOC (system-on-a-chip).
20001 Perguntas Visualizar todos
Why won't my MacBook Pro power on?
I have a early 2008 15" Macbook Pro. It's got the 2.5 Ghz C2D. I received this unit for free because it won't power on.
I ordered a new "T" Magsafe adapter right away and tried it. I get no light on the Magsafe adapter. I tested the Magsafe on my other Macbook Pro and it works fine. I also tried the "L" new style Magsafe Adapter on the broken MBP. No light.
So I took it apart and removed the Left i/o Magsafe board. I purchased a good known working replacement. I just installed that today and I still get nothing. No light on either Magsafe Charger. So it appears that the SMC isn't activating the Magsafe board. Unfortunately the battery was completely depleted when I received the unit, so I can't test that.
I'm trying to restore this to good working health. Does it look like I need to buy a new Logic Board or are there other things that I can try? I did reset the SMC and that didn't do anything. I'd appreciate your input!
Esta é uma boa pergunta?
Pontuação 1
4 comentários
What are the last 3 characters of your serial number? Did you purchase the 60 watt or 85 watt power adapter?
por
Serial ends in YK0 and both of my adapters are 85 Watt Magsafe which is appropriate for a 15". I realize that this particular model has been known to have issues with the newer Magsafe chargers. That's why I purchased a "T" adapter to go with it. So I have a new "L" Adapter that came with my 2010 MBP and then I have the "T" that I bought for this one. Thank you for answering!
por
Apple MacBook Pro "Core 2 Duo" 2.6 15" (08) Specs
Identifiers: Early 2008 - BTO/CTO - MacBookPro4,1 - A1260 - 2198
por
That's very close. It's the 2.5 Ghz A1260 Model. Any thoughts on my issue?
por
Adicionar um comentário
1 resposta
Solução escolhida
A lot of these machine won't power on if the battery is completely drained. If you have a similar machine around try switching batteries. Let us know your results. This machine also has the GeForce 8600M GT video processor which Apple had problems with but we need it to try to boot before going into that.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Right. I'm aware of that video issue. Shouldn't the machine still boot without the battery? I thought that you could still turn it on when connected to MagSafe with the battery removed. Am I wrong?
por
Adicionar a sua resposta
Josh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,494
