Ir para o conteúdo principal
Repair guides and disassembly information for the 16-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2485.
50 Perguntas Visualizar todos
Can keycaps from the Intel 16" (2019) be put on an M1 16" (2021)?
keycaps from the 2019 16” look similar to the keycaps from the 2021 16” but can they be swapped interchangeably?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
UPDATE: I just tried and they fit and work perfectly
Esta resposta foi útil?
Pontuação 0
Since they’re from different generations, most likely no. Although it shouldn’t hurt to try assuming you have some to try out.
Pontuação 0
Just keep in mind the risks! Popping off keycaps is tricky! And presently the M series parts have not hit the open market. So if you mess up you’ll need to visit an Apple Store or authorized reseller to get your system fixed and that could be costly!
Pontuação 0
Adicionar a sua resposta
Vittorio Buffo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 46
