Ir para o conteúdo principal
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150 Perguntas Visualizar todos
Password digits 3,6,9,cancel not functioning
I replaced the digitizer about 18 months ago. It has been flaky ever since. I reopened it to see if I could fix this problem. Now the symptom is the digits 3,6,9,and cancel will not respond when opening password. This symptom is not now flakey but solidly not functioning. I thoroughly cleaned the connectors per your instructions. My question is, is it the digitizer or the processor. Any ideas?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hey Chuck,
Seems to me like a logic board issue as concurred by @beanman56 . With that being said maybe there are dead spots on the screen which are causing this.
Did this happen after an update or did something happen to the device prior?
IMPORTANT NOTICE:
From Sunday Aus to Friday AUS, i will be unavailable as i am camping then.
Esta resposta foi útil?
Pontuação 2
Its the digitizer
i’m 99.5% sure
Pontuação 1
2 comentários:
Replaced digitizer same problem.
por
Sounds like its a logic board problem then :/
Like the software or something
por
Adicionar a sua resposta
Chuck Porembski será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 95
