Can I take a A1706 Logic Board out and put in the body of a A1989
Hello
Can a logic board from an A1706 fit an A1989 Shell as I want to change the screen and the Body is a different colour ?
Thank you
Mike
Esta é uma boa pergunta?
Hello
Thank you
Mike
Sadly, you can’t. There are enough differences which will mess you up. The biggest is the display won’t work correctly as the A1989 has TrueTone services which the A1706 doesn’t so that kills the swap out of the display.
You can find skins to cover your system to change the color or even give it some distinction!
Esta resposta foi útil?
Thank you
Are the 1706 and 1708 displays the same? if not what other displays would work?
@Michael Perkins - The 1706 (4 USB-C port) and the 1708 (2 USB-C port) systems use the same display
∙ 13" MacBook Pro Display - Space Grey (16/17), Apple P/N 661-07970
∙ 13" MacBook Pro Display - Silver (16/17), Apple P/N 661-07971
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 252
