Ir para o conteúdo principal
7.2 megapixels, 3x optical zoom, 2.5 inch LCD screen, released in August 2006
5 Perguntas Visualizar todos
Camera Shows "Lens Error"
The camera powers on, and briefly shows an image on the LCD display. Then eventually it gives a "Lens Error" message.
Has anybody gotten this error before? Know how to fix it, I'm thinking that since the camera shows an image on the LCD, it may be a software rather than hardware problem.
Esta é uma boa pergunta?
Pontuação -1
3 comentários
what error no. does it give?
por
pollytintop, I think it's one of those cameras that just says "Lens Error". Usual cause is sand grid and grime in the rings, a dislodged lens, or faulty lens motor. :-)
por
Any way to fix it?
por
Adicionar um comentário
1 resposta
Solução escolhida
If the lens does not extend/retract properly, then you most likely have something stuck in the zoom gears. If the lens extends but you hear a high pitched buzzing noise, it is the focus motor that is the gears are out or your have debris it it. I would start by reading these tips and see what you get. Also take a quick look at this video to see what you might be up against :-) hope this helps, good luck
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Danny Arenales será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 13,251
