Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1202 Perguntas Visualizar todos
new screen won't attach-- metal tabs broken off?
My son removed the screen on iPhone X (to replace battery) and broke the screen. So ordered a new screen, hooked it up, but when I go to reassemble, it doesn’t want to click-in to the phone body. I’m noticing the removed/broken screen has no metal tabs on the edges, but the new screen has several. Could these metal tabs be broken off in the phone body?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
More than likely when the screen was removed, the actual display came free from the frame it’s mounted to. Included images for reference of what the inside with no display should look like. The silver bit around the edge of the back of the display is likely still seated in the enclosure. You should be able to pop it out with a tool, just be mindful of the battery and other components. The clips just snap in place and will come free with enough force.
Esta resposta foi útil?
Pontuação 3
4 comentários:
This was exactly it. I was able to remove the bracket and attach the new screen. Thank you very much!
por
Thank you for this post!!!!
por
Yep, me too! Perfect!
por
@kcirsnurb Glad people are still running into this and finding it helpful :)
por
Adicionar a sua resposta
sethcrothers será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 64
Duração total: 872
