Ir para o conteúdo principal
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
329 Perguntas Visualizar todos
How do I remove hard drive
iMac 2012 black screen
A1419 iMac, powers on but LED backlighting doesn’t light up.
Apple genius says my drive is dead. I want to remove it and get the data stored on it. They siad there are services that can do this. My last backup with Time Machine is pretty old.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi
It’s fairly easy to do you just need to pop the glass off ,remove the display and remove the brackets that hold the hard drive in place
Heres video that shows sep by step
https://youtu.be/OXmHGrr4Vkk
I know the video is about a ssd upgrade but it’s the exact same process and just a little warning below the hard drive there is a power supply DO NOT TOUCH IT (sorry if that sounds aggressive)but really don’t as the is a chance you could get a shock of if it which I’m pretty sure can kill you ,however I have done the sort of repairs before and had no issues so as long as you are careful you will be absolutely fine
If you have any Questions please ask
Esta resposta foi útil?
Pontuação 2
2 comentários:
Hi
I would recommend using the video that Dan had provided as it is a ifixit guide a will be waaaaaaaay more in depth than the video I provided
por
OK, so here are my recommendations:
  1. Start by confirming your A1419 iMac is a Late 2012 27” with iMac ID 13.2. The following should cover all iMacs from 2012 through 2019
  2. Watch OWC’s removal/installation video here (OWC has been supporting Apple computers for DECADES)
  3. I highly recommend purchasing OWC’s iMac tool kit ($25). You will need to remove the screen, and it is glued in place. Take your time and it will come off.
I do not and have never worked for OWC, but I did work as an Apple tech for 17 years and after trying many companies’ parts, will only deal with OWC to keep my iMacs going.
Take your time and it will all come together.
Pontuação 1
2 comentários:
@mrmattdat - We do try to aim people to the iFixit tools & guides Substituição do disco rígido do iMac Intel 27" EMC 2546
Remember they are the ones offering this Blog space!
por
Gotcha! Love the tools (top shelf!!!!), just never had a chance to use the guides (yet!)
por
Adicionar a sua resposta
Bob Enders será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 91
