Ir para o conteúdo principal
Repair guides for feature cell phones manufactured by Kyocera. This category is for phones not using an Android or Windows operating system.
26 Perguntas Visualizar todos
Why cant I turn it on
My kyocera 3G s1360 wont charge, Save the battery or turn on when i try to turn it on it wont power but when i plugin the cable it flickers but also when i power on it just says hello and the turn off
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @angel_10 ,
Try replacing the battery (supplier example only) and check if the phone now charges and when the battery is fully charged, check if it turns on OK.
I assume that a Kyocera 3G S1360 is the same as a Kyocera Jax S1360 (which is a 3G phone) as there are no results when searching for the former.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Angel LS será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 71
