display occasionally turns white during use
hello
the display goes completely white sometimes. once it has, it’ll work normally again for about a second or two after making the display sleep or restarting the macbook, then it’ll turn white again. the only thing that seems to fix it for more than just a couple of seconds is shutting the macbook down and leaving it powered off for several hours. this doesn’t work 100% of the time, though. the problem might occur every time i use the macbook or not at all for days, weeks… whilst the internal display’s white the macbook still works perfectly fine connected to an external display. could it be the LVDS cable or is it definitely the display? thanks in advance
Update (07/01/2022)
@danj - did as you suggested and took a picture
Update (21/01/2022)
@danj - took a screenshot of coconutBattery’s main window
Esta é uma boa pergunta?
