Ir para o conteúdo principal
Sony Cyber-shot DSC-W150 is a 8.1 megapixel point and shoot camera with a 2.7" LCD display.
15 Perguntas Visualizar todos
lens keep going in and out
why do the lens keep going in and outk, and on the message it says to turn the camra off and on again and when I do it the same thing happens again. Unable to take pics.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Beverly, it does sound like your lens is stuck and can not fully extend. Check on here
"Lens won't fully extend ¶
Screen shows Turn off and on again. ¶
Turn off the camera, remove the batteries from the camera and wait a few minutes. Replace the batteries and turn the camera on.
If the lens will still not extend, replace the batteries and turn the camera on.
If the lens will still not extend, check to see if there is any particles in the lens barrel. Blow air in the lens barrel to remove any sand or grit that may be preventing the lens from extending completely." There is also more generic information about that on here. You will find a decent video (not exactly your model, but same problem), on youtube
Esta resposta foi útil?
Pontuação 1
I would turn it on ..and with alight force..pull it in and out the same time as the camera and the teeth will start working on the cogs..I fixed many cameras like this ..
Pontuação 0
Adicionar a sua resposta
Beverly será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 97
Duração total: 7,899
