Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Perguntas Visualizar todos
Can I… Or should I Update?
I just got a mid 2011 iMac running OS X El Capitan. If I buy the upgrade kit would I be able to update my operating system?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
You should be able to upgrade it (to high Sierra) without the kit.
Esta resposta foi útil?
Pontuação 0
Here’s a link to the macOS files How to get old versions of macOS
I would recommend creating a bootable OS installer thumb drive and given the system you should stick with Sierra (HFS+ file system) or if you need something newer I would go upto Mojave (APFS file system) but that will require DosDude to run. High Sierra has issues!
Format the USB with a GUID partition map and a Journaled File System before setting it up following this guide How to create a bootable macOS Sierra installer drive
Pontuação 0
Adicionar a sua resposta
Jeremy Crow será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 55
