Here are some basic troubleshooting steps:
1. If the picture on the screen is vibrating, or seems like it's shimmering etc, it could be the refresh rate is set improperly on the monitor or the resolution is too high.
2. Before we go there, however, the quickest first thing I would do is just press the menu button on the monitor itself and access the monitors menu to do a factory reset. Sometimes you get lucky.
3. Ensure the monitor cable is tight on both ends. Shut off the monitor, reseat the power and monitor cable, then turn it back on. If you have another cable, test it with that to rule out a bad cable.
4. Make sure the monitor isn't near anything magnetic like speakers or microphones etc, or anything which gives off waves of any kind. Like a wifi router, etc. This shouldn't affect newer lcd models, but you never know.
5. If that doesn't help, check your refresh rate and resolution settings under the display options in your control panel. If you have it set to it's highest resolution 1600 x 900 move it down to the next lower resolution. If you just replaced a CRT monitor, maybe you have to increase the resolution/refresh rate to 1600 x 900 and 60 mghz.
6. Lastly, if all else fails, and all the hardware appears to function properly (test the video card with a non-lcd monitor, for instance, and see if that works) then I would update the video card drivers.
Let me know if any of these things worked, and if not, we can maybe figure something else out.
3 comentários
Try booting it to the BIOS to see if the screen shakes there. If it shakes in the BIS it is definitely hardware related. It could be a bad video or display driver if it only does it in Windows.
por ABCellars
My monitor blinking 3-4 times per Second . What can i do now?
por S.M RAKIBUL ISLAM
Hi @S.M RAKIBUL ISLAM,
What is the make and model number of your monitor?
Did you try another monitor connected to the source of the signal to prove whether the problem is with the monitor or the source of the signal. e.g. is it the computer or the monitor that is the cause of the problem?
Does the monitor's OSD (on screen display) menus stay on and not blink?
What have you tried?
por jayeff
